I have a situation where we have altered nearly 100 new circuits purely by adding a cable from the supplied isolator to a 3p+n plug to supply pumps. Each isolator is on its own circuit from the local DB and we need to issue certs for all these alterations, I was curious if there was a recommended faster way to cert all the alterations as 100 minors works certs seems a bit excessive.
The NICEIC online certification process has a 'duplicate' function, but will only duplicate some of the information. Some will still have to be entered onto every certificate though.
Wales
United Kingdom
Electrical Engineer (Qualified)
Best solution to minors works certs for over 100 circuits only altered with a 2m cable from an isoltor to a plug?
jacobwelch,
DefyG,
TrueNAS JBOD Storage Server
