Best water pump pliers | Page 2 | on ElectriciansForums
Discuss Best water pump pliers in the Electrical Tools and Products area at ElectriciansForums.net
so many cases where you can't get any make of grips in to tighten locknuts, due to lack of clearance. that's where the hammer and cheap screwdriver is king.
The Bahco ones I use have a taper to the jaws.
If you lay that taper flat to the surface the lock ring is on, it lifts the handle so it misses most obstructions.
The thin jaws can get between the surface and the nut which means you can tighten or loosen the gland without touching the nut.
Can’t recall the last time I had to use a hammer and screwdriver on a gland.
the problem is when the gland is so close to the structure of the enclosure. on some i've even had problems getting a locknut on, knockout being so close to the back of the box. even had to use a lock ring on several occasions,
Wedging something in between the nut and the obstruction usually does it for me.
I have modded a couple of pairs of thin-jaw Bahco adjustables,by further grinding and altering the jaw profile,for certain jobs. They are invaluable,and without adding tubes and grunting,have not suffered any strain evidence.
I know it won't be popular,but i have been doing this mod since i was a kid,on a plumbers advice...my first being a round jawed Bahco,someone threw at me dad,at a football match:confounded: ground over a morning,using a giant,aluminium bodied Wolf 9" grinder :)
PS; if you grind a pair,alter them on opposing sides,to leave the option of untouched faces working,flush together,when a pair are matched. It also is sometimes beneficial,to have a choice,for access reasons.
Bahco for me, every time...they were so impressive that a plumber working on my house nicked them...bas***d!
Aye, true, Tel...and me bob-stay's like a broken violin...
and me triassic has a catenary to shame a saggy washing-line
I have a few pairs of basic Knipex alligator grips. They've always been good enough for me. Rarely come out the bag though as I tend to prefer other tools.
+1 for knipex, ive got 2 pairs from when I was a lad in the late 90s and still serving me well 20 years later!!
thsat's nothing. i have a voltmeter made in 1934 and still use it. cased in oak wood (that's something that grows on trees, not in Ikea). it has a moving coil needle, not some stupid 14 digit display that reads miillivolts when there's nowt there.
Reply to Best water pump pliers in the Electrical Tools and Products area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
    • Friendly
Thanks so much for sharing this with us! I’ll definitely take a look, it seems like there are a lot of useful and interesting products. The idea...
Some year back there was a case of a young girl killed by being sucked down to the bottom of a pool when being emptied through the power drain...
M
Rubi DC-250 1200 Water Pump Replacement Hi, I'm really hoping someone can maybe help. I have a Rubi DC-250 1200 and it looks like the water pump...
mattwaddy
M
