Best way of supplying summer house | on ElectriciansForums
Discuss Best way of supplying summer house in the UK Electrical Forum area at ElectriciansForums.net
Luton
Hi guys
I am taking on a job of supplying/wiring a summer house which is in the process of being built.
Consumer unit has no spare ways so my only option really is splitting the tails in the meter cupboard into a fused isolator to supply the SWA. However as far as I’m aware I am not allowed to install an isolator in the meter cupboard and the client is getting this signed off by the council so I need to do everything properly. Are there any ways around this? Even if I wanted to add a new CU I would still have to split the tails so it seems to me that there is no way around this.
Also the summer house is only going to have 10x sockets and 6x spot lights so I don’t see any reason to use anything bigger than 6mm SWA. Main cutout is 100A so I will need a fused isolator to step the amps down to 32A (SWA is running in duct under the floor) do they even make an isolator like this? 63A is the lowest I’ve seen so I will have to run in 16mm SWA to support the 63A from the isolator? Seems overkill to me
could you draw out the sub mains to consumer unit in the out house ,loading factor ,design .
in the olden days when there were no spare ways in often already cramped fuseboards we would add a 20amp single way shower consumer unit to the downstairs rfc to feed a small shed our garage. exactly the same way you would add a 13a swi spur to a ring but the 20a consumer unit gives you a bit more load capacity
Meter cupboard is on exterior wall. Consumer unit is literally on the other side of the meter cupboard under the stairs (inside obviously) PME system
Then about a 25m run from the meter cupboard to where the consumer unit in the summer house will be going. Trenches have already been dug I just need to lay in the SWA and duct-in
I’d say even 6mm is overkill for a couple sockets and lights but I’m thinking of future proofing it.
I’ve done work like this countless times for my boss - splitting tails for sub-mains etc but it usually specs for 16mm t&e coming out of the fused isolator so obviously I can use a 63A fuse. But in this situation I cannot fuse 6mm SWA at 63A as I believe highest it can handle is around 47A clipped direct but I will be running under the ground.
Basically what I’m asking is how do I fuse the amps down to 32A or 40A for the SWA from a 100A cutout. Am I being stupid and just overthinking this? Can I not just buy a 40/32A HRC fuse and stick that in the fused isolator?
She wants it to have its own separate supply and also said in the future she may add heaters and some other things
10mm swa , fused switch 40amp .job done you need to work out the vd on your loading .
What's wrong with using a 2 way consumer unit (garage unit), 63amp rated.
You've 2 ways available to take whatever supply you want....under 63amp.
Reply to Best way of supplying summer house in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
Has the cover been removed, is it TP bussbar? I fitted one as @oscar21 linked to a few months ago, it was actually a nice board and with the TP...
