Best way to add new sockets in existing stud wall | Page 2 | on ElectriciansForums
Discuss Best way to add new sockets in existing stud wall in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Got it Lathe and Plaster, thick Northerners want to learn to spell. Laffin plaster???
Thanks for the replies. To my surprise the walls are plaster board. I expected lath and plaster myself. Some of you relate too drilling a hole up through the base board of the timber frame but this would be impossible to do under the floorboard as there is no way of manouvering a drill within the space under the upstairs floorboards. Is there another way?
cut out back box where required, then drill down. flat bit or auger with 12" extension.
a lathe is not maggie thatcher. it is made for turning.(wood, metal, or for southerners, cheese).
OK Lath and Plaster just added the e so you Northerners would be able to understand.
Reply to Best way to add new sockets in existing stud wall in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
