Best ZE on TT | Page 2 | on ElectriciansForums
Discuss Best ZE on TT in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
But surely, ....No-one can achieve TN values, or a sub 1 ohm Ra values from a Roded TT system!!! Well that's what some here would have you believe anyway!! Others just don't even bother and put all they're faith in a RCD!! lol!!
Course they do, they forget to disconnect any parallel paths.:o_O:
On the 13 ohms I mentioned, with bonding connected to gas and water supplies, when i took the measurement again, the Ra had dropped to 0.3 or there abouts
That would be Zs!! And i doubt very much that any bonding would pull your Zs down to 0.30 ohms. ....Not unless someone down the street has a PME connection, as both the water and gas main pipes generally have an underground protective anti corrosion covering...
No seriously E54, i'm being genuine.
Zs at origin then i suppose.
I don't disbelieve you, far from it. But there will be a reason for that dramatic fall in your Zs values, and the most likely one being PME connections along the street. Be they official or unofficial PME connections. ..lol!!
Yes, you're right E54. Its only 3 small cottages that are TT, for some reason everything else has been converted at some point.
Water is still supplied in lead which pretty sure won't have any corrosion protection applied.
You say that, but my parents house had a lead water supply, when we came to add an extension and dug out for the foundations, that lead pipe had a DENSO type tape (Grease impregnated tape, ..horrible stuff) wrap!!
Oh yes, know the stuff well. Takes days to clean your hand up after using it!
Its just from other experiences really with working in close proximity to this place. Other houses have alterations done and only ever seen the lead naked in the ground.
Know what you mean though
Reply to Best ZE on TT in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
For what OCD? There may be other means of over current protection that allow a Zs of0.45 (HRC Fuse?)
G
What's the Best Tile Adhesive for Floor and Best Tile Adhesive for Walls? 2013 Which Tile Adhesive Did You Use Most During 2013? Please vote on...
Gazzer
G
