Ok thanks I'll look into that, I've not posted for a while! I'll post pics of the board at the weekend when I've been for a looksie. Whats img wrapper??
ok, when you go to post a reply click on advanced,
if you click on image you can post a url to your images
by wrapper i mean the code that tells the forum what it is
for example [URL tells the forums its a link
[IMG tells the forum its an image and it will show it as a pic
Ok I'm on android phone app at the min and doesn't have all the options of the website so I'll do it from the laptop when I have them.
You should get tapatalk as you can upload pictures direct from your phone with that. I would do it myself but would get a long ban for posting a picture from my phone.
I suppose it makes a change “my friends next door neighbour” as someone to blame when things go wrong.
she also needs to tell him that HE will arrange notification in accordance with part pesh. If he hums and hars she should threaten him with LABC (who will do nothing but he might not know that)
I thought this was ultimately the homeowners responsibility to inform LABC?
I don't expect the two events are related. There's nothing you can do at the CU to 'alter' how the laptop charger works - either it gets 230V between L&N in which case it charges the laptop, or it doesn't. Polarity doesn't matter. Inside the laptop, the 20V DC - or whatever the charger produces - is converted to various other voltages including 5V for the USB output. So even a malfunctioning laptop charger would, as you say, normally fry the laptop innards first, before affecting anything plugged into the USB ports.
The only really obscure and nasty scenario I can invent to connect the two is that the final circuit that the charger was plugged into had its CPC connected to line at the CU, making the laptop chassis (and probably everything else in the room) live. Then somehow the output side of the bike lamp charger contacted real earth potential and the fault current passed through the laptop charger and laptop DC ground without visible harm but fried the final link in the chain.
Other than this almost-inconceivable occurrence, it's just coincidence.
It's hard to get enough power out of a USB port to do real damage, even at 2A it's 10W, half a soldering iron's worth of heat. But if something on the output side shorts, the lamp battery might discharge back into the short and even a small LiIon can pack a punch and burn things out sharpish. Also, some of these products are not made of properly self-extinguishing plastics so once something gets too hot, the whole casing bursts into flame.
I would be interested to see a close-up of the PCB from inside the charger. I see a lot of blown-up power electronics and can often reconstruct the chain of events.
These switch mode chargers are downright dangerous, I've personally had two that have gone molten and I know someone that lost the contents of his garage because of one that combusted. I've now set up a single charging shelf in our house with a large multiplug which is on a 24 hr timer so it switches off at 11pm and back on at 7am, that way there won't be a fire when there's nobody around to deal with it.
I agree with Lucien, it's highly unlikely the charger fire was related to anything happening in the CU.
These charges are extremely dangerous, especially cheap imported ones that swamp this country. Saw one on TV other day, whereby a visitor to a friends house plugged in an e-cigarette charger. It ignited and burnt all the kitchen out! There are numerous reports of these things going wrong.
I saw one on one of those consumer programs like watchdog, where one woman bought a charger from a market whilst on holiday, for her grandson's device and it electrocuted him.
Did you check the ends of bike light charger. I know had smart phone chargers where the ends are loose or broken in the cord ends
Nottingham
Bike light charger fire
Security Alarms, Door Entry and CCTV (Public)
new_spark,
mike the bull,
