Bit of help with a TT installation please... | on ElectriciansForums
Discuss Bit of help with a TT installation please... in the UK Electrical Forum area at ElectriciansForums.net
timo1
Hi, i'd appreciate a bit of help with this one if poss. Went to look at a job on a TT installation, property was a single story bungalow and has since been developed with another floor. As usual everything has been immaculately decorated, floors laid etc..and no thought given to the electrical services!! New owner is very realistic and happy to upgrade bonding, along with a decent bit of extra work.
I have checked and there is a 16mm earth from the earth stake/rod outside which goes directly into the C/U. there is no bonding present on either the water or gas. C/U is in the middle of the house, gas is positioned on the outside wall about 5 - 10 metres from the stake.
Ideally I would like to run bonding from the gas and water to the C/U but this is not an option, I'm all for a challenge but the route has me beat.
One solution I thought of would be to create a MET near the gas position and join the main earth and gas/water together, possibly in a weatherproof enclosure, obviously clearly labelled at source and at C/U. Property is RCD protected also.
Not ideal I know, looked at regs and can't see anything directly against it, any thoughts? Thanks in advance.
so, what you are saying is that you will fit a MET close to the gas and water, use the 16mm from CU to MET, then MET to rod, and bond gas and water to MET. if so, as you say, not ideal, but as long as correctly labelled up, and readings taken. sounds like a plan
Great news, thanks for taking the time to help, time to do some sums for the estimate!
Yes mate all protected, one RCD up front, again not ideal, maybe able to persuade to upgrade (that rhymes)
its back to the DB im afraid otherwise walk away from other works
don't know of any reg. that says a MET can;t be remote from the CU. esp as he's got a 16mm when the minimum is much less for a TT system
i will await the opinion of greater minds than mine. was thinking of flicking through the bgb, but a more pressing matter requires my attention. beer glass is empty.
Reply to Bit of help with a TT installation please... in the UK Electrical Forum area at ElectriciansForums.net
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
