Bizarre Wiring And Readings Through Upstairs Windows | Page 3 | on ElectriciansForums
Discuss Bizarre Wiring And Readings Through Upstairs Windows in the UK Electrical Forum area at ElectriciansForums.net
G
Gemma
Hi
I don't know if anyone can help, but I'm very grateful to anyone who can provide input. I won't go into the full story, but my windows upstairs appear to have an electrical current running through them.
It's only the windows upstairs.
They also set off a radio frequency detector.
Even if the fuse box is powered off, they still give an electrical reading.
It is not a home security system. Just bog standard double glazing.
The house was re-wired (not by me) and the electrician I had over recently noted what a mess it was and the upstairs and downstairs aren't on seperate circuits.
I have a photo, but I can't attatch it. It shows the window handle giving off a 12v reading, the same as my power points.
I also have a video of the windows setting off the radio frequency detector.
My friend, a glazer, came over and used a thermal imaging camera and we noticed the windows had unusual hot spots on the frames.
I have a feeling it may be being used for some kind of surveillance system that I am unaware of.
Very weird question I know, but any advice is greatly appreciated.
parabolic.... similar to alcholic, but a parabolic has a tendency to parachute out of perfectly good aeroplanes. due to the forward speed of the aircraft, until the parachute opens, the parachutist's travel through thin air describes a parabola. hence the term.
bolics
I know this is a silly movie, but it's got aliens (so maybe connected to the OP?) explosions and very big 16" guns that fired projectiles weighing a ton over 20 miles. And that track :)
Best bit is 4:30 ...
The solution is to buy copious amounts of aluminium foil and put this on the walls behind the paper and paint. cover your window panes with the foil and it will protect you from the potentially harmful currents and signal waves. All just in case you are being monitored. If you have any foil left on the roll you can make a hat to wear when driving and out the house.
Reply to Bizarre Wiring And Readings Through Upstairs Windows in the UK Electrical Forum area at ElectriciansForums.net
Thank you, what would be the advice for me to do in this scenario? I've also seen circuits tripped in past from other things such as 1500VA step...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
Recommended Sponsor News
Hi everyone,
