Board changes, customers and EIC's | Page 5 | on ElectriciansForums
Discuss Board changes, customers and EIC's in the UK Electrical Forum area at ElectriciansForums.net
Leeds
Evening..I just wanted a bit of advice on the procedure to follow with regards to consumer unit changes, advice to customers and how to fill in an EIC. I have recently changed a consumer unit and I informed the customer beforehand that there may be faults on the system when the cables are checked. Low and behold when I checked the insulation resistance there was a cable down on a circuit. I have told the customer about it and told them I can investigate further, they then told me that they couldn't afford me doing remedial work and they would sort it out at a later date. How do I then fill out the EIC knowing there is a fault on the installation?
As mentioned one needs to see through "muppet" type digs, and take it in the correct way as in not personally.
i for example am a prize muppet of the highest order. I am a muppet. And a plonker sometimes. Even electrically.
I am a Muppet. A muppet.
Spartykus has spoken.
At this point we all stand up and declare 'I'm a muppet' :oops:
you make yourself appear incompetant by asking stuff in here that if you were competant you would know what you were looking for upon initial survey, the pre-tests to carry out, and the paperwork required upon completion....
in fact...i have just read this one a few days after it was first posted....
constructive criticism....lol...you should thank god i didn`t get here first....
go away and get competant....before carrying out any more board changes....or touting for such works from unsuspecting customers...
competent
This is the correct spelling Glenn.
Reply to Board changes, customers and EIC's in the UK Electrical Forum area at ElectriciansForums.net
I'm begining to think like this now, I very rarely work for builders anymore but the couple that I still do work for are the worst payers out of...
    • Agree
Promised a photo…. Remember, this was working…. And they managed to move in without hitting it…
