Boiler Controls: Honeywell Equivalent to Randall 103 | Page 2 | on ElectriciansForums
Discuss Boiler Controls: Honeywell Equivalent to Randall 103 in the UK Electrical Forum area at ElectriciansForums.net
Market Harborough
Hi,
I am replacing an old Randall 103 boiler controller for a customer but not 100% which one I need, I did order the Honeywell ST9100C, but just need a bit of confirmation that it will do what I think.
Basically the one I have puts power to the boiler and power to the pump, and thats all the new one needs to do.
Does anyone know if this one will do that? I am sure it is the right model, just need a bit of guidance please.
Also on another note, my father in law has a Randall 3060 and wants a new one as its making a strange noise all the time, so again, does anyone have any ideas as to which Honeywell timer would replace it?
I can't say I've ever looked for one or even thought about it actually.
I only think about it when I'm at the job and it's just as quick to trace the wiring of the whole system. Plus it's always better to confirm that the programmer is actually at fault, just because it makes an odd noise and the heating misbehaves it doesn't necessarily mean it is the programmer
Well i went round there last night and looked and its barely ticking and he said its not too bad... typical!
Anyway, I changed the Randall 103 over this morning for a Honeywell ST9100C, worked a treat, wasnt a 100% which was to connect it as theres no stat and the manual is aimed more towards a combi with a stat.
they normaly do the brass washers and fingers get sh*-*-* up to hell and stop the mech working nice and free
Reply to Boiler Controls: Honeywell Equivalent to Randall 103 in the UK Electrical Forum area at ElectriciansForums.net
yeah, I installed the new one. Last one looked like it had its days, just cut out some cable routes in the back box and connected it up. Yep mate...
You need a wi fi switch that is compatible with your switchbot thermostats. Remove the SCR, use the neutral and live to power the wifi switch, and...
