Boiler in bathroom? | on ElectriciansForums
Discuss Boiler in bathroom? in the UK Electrical Forum area at ElectriciansForums.net
N
Noob2013
Hi all,
What's the situation if someone wanted the combo boiler fitted above the toilet in a bathroom with a shower?
Chances are it will be in zone 2.
Is it not allowed or is it acceptable if it's boxed in?
Would the FCU need to be in the loft or outside bathroom if it was boxed in?
is it in the plumbers guide for dummies, the one that says all the pipes at the boiler must be cross-bonded when they're all electrically bonded anyway?
It has to be mounted at a suitable height so as to avoid clashin; yer heid on it when rising from a sitting position on the pot.
As for the leccy bit I'm thinking a patress box with two flex outlets - one for power and the other for control - with the "means of isolation outside of the bathroom.
If you're really clivvor use something like a 5 or 7 way flex and then you only need one flex outlet on a single patress box. ;)
With regard to boxing-in etc........ RTFM!!!!
[ElectriciansForums.net] Boiler in bathroom?
stick it on the |CU that the builder has conveniently positioned so you don't need steps for access. just stand on the bog. whole estate near me done like that.
You may not believe this but I assure you it's true: My doctor's waiting room has a TV screen mounted about five and a half feet up on the waiting room wall directly above a seat.
Fine if you're someone of Tel's stature I suppose. ;)
Hi all,
Are you allowed a gas boiler in a bathroom? I'm thinking about from a gas point of view, air flow, fumes etc. Also the likely hood of an extractor fan being installed.
Reply to Boiler in bathroom? in the UK Electrical Forum area at ElectriciansForums.net
Unfortunately my boiler is in the bathroom. Whoever had the house before me did some DIY frame and doors. Fortunately it meant I could fit a...
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
