Bonding combi boiler gas pipes | Page 2 | on ElectriciansForums
Discuss Bonding combi boiler gas pipes in the UK Electrical Forum area at ElectriciansForums.net
London
From my understanding you need to run both a 10mm earth from CU to water stop clock and seperate 10mm to gas, exception being if cable is uncut can link both gas and water together. In a scenario where been asked to change consumer unit but getting to gas pipes of combi boiler is practically impossible what are options. My thinking is that if water pipes tested and proved to be bonded correctly why would it not be feasible to link out water pipes and gas pipes of combi boiler. This then brings all pipework upto to same earth potential no?
Usually at the most convenient place! Where there are a number of steel structures in the ground I do usually do a visual verification that various sections are bolted together and do an R2 test to a few sections after the bond is connected. Granted though in general little thought is given to bonding extraneous steelwork
Admittedly I bond to the shortest route from the MET , as long as it’s accessible for I&T, whether this is completely the correct method, I don’t know?
Reply to Bonding combi boiler gas pipes in the UK Electrical Forum area at ElectriciansForums.net
This is an RSS feed of thread: Changing from system to combi boiler with under floor pipework. Content of the thread: Wondering should i change a...
A
Gas Boiler and Radiator Replacement I bought my house 31 years ago with its 8mm and 10mm micro central heating pipework and existing radiators...
Alan Wright
A
