Bonding dilemma | Page 2 | on ElectriciansForums
Discuss Bonding dilemma in the UK Electrical Forum area at ElectriciansForums.net
growler
Basingstoke
So I turned up to a job today to install an electric heating system for a company I sub for and straight away found that there is no main bonding to either gas or water. They have recently had a new extension / kitchen and a new consumer unit ( no cert though). The gas bond is not an issue as the meter is located next to the consumer unit but the water bond is a fair distance away and the customer is adamant he doesn't want me to disrupt his house anymore than it is already. I can't just walk away either as their wet system Central heating has been removed and the couple are in there 70s.
what to do ?
Has anyone tested the water main to see if bonding is required? I know the regs are worded in such a way that it reads as though services must be bonded regardless, but if testing proves it to not be extraneous then it would be an exercise in futility
Thats why I expressed the term if required... I assume all those posting know how to assess if its required or not :)
To add a note here .... this thread would be a prime example of the difference between a cowboy and a competent professional Electrician -
- The cowboy would quote for the work and not be concerned about the earthing or if he did find it missing wouldn't raise an eyebrow, although it may be a passing comment. (quite often the cowboy is also a qualified professional which is shocking .... pun aside).
- A competent professional would look as a priority when quoting the job and would include it if required as part of his quote with an explanation to the customer about the need for it in there particular install... this way they have been informed and if joe cowboy comes along cheaper and without bonding costs then the customer has made a choice knowing the risks.
Some of you lads amaze me. If this was a"Electrical Trainee" suggesting this he would get pilloried. It is supposed to be set in stone, as in the OSG and all other guidance, that no work should take place unless the correct earthing and bonding is in place. Now we can just adopt the "sod it let's crack on" approach then? And some of you would be the first to moan about the demise of the industry.......
I am a Electrical Trainee and if a customer doesnt want bonding then I just tell the customer it needs to be done and include it in my quote. The regs are there to ensure a safe installation, they dont make exceptions because someone doesnt want decor damaged! This may surprise you time served chaps but this was covered in my training.
I have seen a few board changes with no bonding put down as a deviation!
You can't just tell a customer what work you are going to do regardless of whether they want it done or not! The most you can do is decline to carry out any work.
Electricians have no legal power to dictate what must or must not be done in someone's house.
When it come to bonding, I tell the customer what needs to be done if they want me to do the work. If they dont want bonding, they dont instruct me to do the work.
The net effect is the same, they dont want bonding done, I dont get the job
Why were some houses wired back in the day with no bonding anyway ?
Back in the day the gas and water pipes were commonly used as the earthing system, don't forget lighting was not earthed and the nature of incoming supplies has changed too which rises the risk of network faults piggy backing on bonded services.
So in answer its down to evolving regulations to make installs safer, changing supply systems (TNCS / PME).... there was a time when earthing of any kind wasn't done but thats back in trev's days...
It's frustrating, but you got to stick to your guns. I got a call to replace a shower for a landlord (nobs most of em), no main earthing and no bonding, told them it had to be done. Didn't get the job, and was working 4 houses down the next couple weeks so went and had a look in the outside meter box, still got PME terminal sitting there nowt connected. What can you say.
Reply to Bonding dilemma in the UK Electrical Forum area at ElectriciansForums.net
