brs73
hello there
a quick question.
what methods would you use to bond a large (possibly 4inch?) gas pipe???
thanks
a quick question.
thanks
Discuss bonding LARGE gas pipes in the Australia area at ElectriciansForums.net
hello there
a quick question.
thanks
Knock an earth spike through it.
hello there
a quick question.
thanks
If it's plastic I wouldn't bother, if it's in a commercial/industrial premises and the gas isn't connected yet why not get a stud welded to the gas pipe then fit a lug to cable.
Same as a small gas pipe except I would use a couple of clips joined togther and both screwed up tight.
(Don't forget to burnish the pipe before connection)
Reply to bonding LARGE gas pipes in the Australia area at ElectriciansForums.net
