dasrik
Hi Guys,
I work for a large food factory, a couple of days ago a chap was electrocuted from a machine that had a bonding issue. Now we are being asked to check all the bonding on our machines.
But before i do i want to be sure what the requirements are, so far what i have found on machinery is pretty vague.
On the majority of our panels the incoming supply goes to an isolator and the earth is made off there and then taken to a bonding terminal or din rail earth connector. Is this ok or should the earth go to a MET first?.
The accident was caused by an earth coming off the din rail and not being connected to the MET a fault occured and the panel became live.
I want to find out what the right way is and what regs cover it if possible.
Cheers
Cheers
