Specialist
Specialist - The panel was modified after the accident (i don't know how much) but i'm pretty sure
it shoudn't of been touched at all, now the panel has been removed and the unit has been returned
to its original state which was pneumatic controls.
I don't know too much about the injury's the guy has but he is still in hospital and probably will be
for a while, with dislocations and fractures to at least one arm. Apparently he will need 2 operations to
re-set the dislocations. As far as im aware this was just from the shock!
i have been pestering for BS 60204 but still not seen it, i am now refusing to work on any panel until
i can be sure of the regs and have locked off a machine due to inadequate earthing. The annoying thing is
someone will probably of put it back in service over the weekend.
Ooh that stinks of cover up does'nt it ? Hope the Guy is going to be OK, was he working on a ladder or something when he got shocked ?
Just make sure to CYA by documenting everything you do & why you do it, if you lock off a machine then make sure you keep a note of it in a small notebook. It's too easy for Factory records to Dissapear.
Appologies if i'm preaching to the converted mate.
