Hello wonderful people !!!
I have just noticed that my gas pipes have no equipotential bonding!:eek: The Gas meter is outside about a meter away from my MET. What would be the best way to bond this? Would it be to fit a clamp within 600mm at point of entry to the house and down to the MET? or what's the easiest as the gas pipe enters my house on the opposite side of the house to the MET.
How would you guys do it?
Cheers
Mark
the reg is it has to be bonded to the gas pipe at the meter or with 600mm of the meter but it can also be 600mm from entry to the property as long as you have accsess to the bonding piont. this all has to be conected to your main DB or met at the cut out. you say your met is next to the meter is it a TT system
If the gas meter is so close to the MET then why not run out to the gas meter cabinet and install your earth connection in there. Surface run if unobtrusive or bury it if suitable, just make sure it is at the correct depth and protected from damage.
Thanks Stretchyboy
That's where I'm getting confused. I thought you could install it to the meter if the meter was inside the house! If the meter was external then 600mm at point of entry to the house!
Can I actually go through the wall and outside to the meter???
Of course you can, the gas board actually recommend it for external gas meter housings as their guys can see that it is done without having to enter the property. We've all had our favourite customer ring us up and say" the gas man said it didn't appear to be done" or they've sent a letter saying if have to get it done etc.......
Swindon, Wilts
Bonding
Australia
Mark.W,
Guest123,
