A
axel132132
So ive been to this house today to quote a new Consumer Unit,
Checked everything all good except no bond to Gas or Water, SO i look for GAS yep gas good then i go to the water..
NOW there is a bit of pipe that comes from the ground.. this sticks out about a CM... then the isolator is there, then STRAIGHT AWAY like not even a stem of copper or anything there is a copper T straight of the isolator, from that plastic..
Now what do i do here?? No were can i fit a clamp?? No were can i bond the pipe.. I cant exactly just strip back the copper cable and solder it to that tiny little T piece of copper..
