View the thread, titled "Borrowed Neutral on lighting circuit" which is posted in Periodic Inspection Reporting & Certification on Electricians Forums.
I guess he's common inch smoke line and neutral with ground floor lights. Disconnecting existing neutral from landing light, and using smoke cct neutral for upstairs light. Not sure I would be happy to do this
- - - Updated - - -
Typo. Commoning not common inch ! Bloody predictive text
My personal opinion is that a ecir should be done before and works take place. Weather the house is being sold or not a board change should not happen until you know the system is safe and compliant to handle it.
I mean you check your parachute after you’ve jumped.
Reply to the thread, titled "Borrowed Neutral on lighting circuit" which is posted in Periodic Inspection Reporting & Certification on Electricians Forums.
