Brick lights in timber | Page 3 | on ElectriciansForums
Discuss Brick lights in timber in the UK Electrical Forum area at ElectriciansForums.net
Hi there. I am just about to start a job that entails installing a load of brick style lights into railway sleepers. Any thoughts on the best way to cut the hole out? I was thinking of drilling a load of holes with a wooden spade bit inside the shape of the hole then chiselling any corners out. Does anyone have a better idea???!
Thanks,
Dave.
I use a corded Clarke one from machine mart. Does the job and was about ÂŁ45. There are a few other brands at that price too.
Battery units of any brand will be a lot more expensive, apart from the aldi ones.
I bought a ÂŁ20 one from Aldi in a case the other week , I could not resist it.
I used it a few times and must say it is mint. 300w and variable speed it's a bargain.
The only thing is the blade base , it has prongs and is tightened down by an Allan key boss and has come loose , but prob because I was frightened I had over tightened it.
It is cheap enough to leave in the vehicle and have to hand for those unexpected uses.
Thanks for the much appreciated input guys! Just an update. They are big slabs of oak, so not to bad to drill through. Although i did stock up on some spade bits! I decided to use a spade bit for around the edges and then used a reciprocating saw to cut through the rest. It took about half an hour to cut the opening so not too bad. Although very intensive on the batteries!
Cheers again!
As a few others have said 100% use a router. Would take a chippy no time at all to do once a ply jig is made. You would end up getting vibration white finger (or whatever it's called) if you did a load with a multi cutter.
Routers are easy enough to use, you could hire one.
I haven't got a router , how deep a cut can you get with them.
Not sure on that. I have cutters that can go approx 50-60mm deep. If the cutter was not inserted fully could probably go to 75mm. I usually use it for kitchen worktops, so rarely go past 40mm. They take a lil while to set up but are a good bit of kit to have.
Thanks for that. It's mainly kitchens I've seen them used on.
I often fancied getting one .
I do 70% elecs and 30% joinery. Never found much for use it for electrical work tbh. I did route out a channel for a telephone cable once but that's the only time I can recall. There's quite an art in getting a decent masons mitre on worktops. It's also good for letter plate holes in front doors.
i got the aldi 10.8V and the 240V. both good bits of kit, but the cordless, i burnt the speed control out. just bridged it out so it goes full speed all the time.
To be honest I was surprised, I have a Dewalt 350w too, but I don't leave it in the vehicle. With the exception of the blade fitting the Aldi one does the job just as good, and I leave it in the vehicle overnight for those days you don't think you will need one.
PS ,based on your recommendation I will get a cordless the next time they have them in.
I bought the headlamp you recommended .
Reply to Brick lights in timber in the UK Electrical Forum area at ElectriciansForums.net
Back to the Men's Shed today to complete the installation of the 4 LED battens in the attic. These were a joy to fit, having screwed the units to...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
