Hi People on an install I have come across a British General outside socket that is reducing the Insulation Resistance when i remove the outside socket the IR goes back up has any one come across this before
Thanks phil
Thanks phil
Discuss British General outside socket in the UK Electrical Forum area at ElectriciansForums.net
No never haveHi People on an install I have come across a British General outside socket that is reducing the Insulation Resistance when i remove the outside socket the IR goes back up has any one come across this before
Thanks phil
Hi it's a brand new socket and non rcdHi People on an install I have come across a British General outside socket that is reducing the Insulation Resistance when i remove the outside socket the IR goes back up has any one come across this before
Thanks phil
Well therein, lies' your problem I think. Were your IR test L to N? or LN to EHas it got a little neon indicator on it?
Agree Tel but we have nil info on test results or how the tests were carried out.neon should only affect the IR if the socket switch is in the ON position.
As per Tel' response, test with the socket switched off, or removed from yje back box bye still connected, AND GIVE US THE RESULTS OF YOUR TESTS PLEASE.Hi its between line and neutral the line conductors and cpc are fine I am not on site but I can not recall it having a neon but could be a poss
phil
Reply to British General outside socket in the UK Electrical Forum area at ElectriciansForums.net
