Hi People on an install I have come across a British General outside socket that is reducing the Insulation Resistance when i remove the outside socket the IR goes back up has any one come across this before
Thanks phil
Thanks phil
Discuss British General outside socket in the UK Electrical Forum area at ElectriciansForums.net
or both of them. but only in circuit with switches ON. and i think BG are using LEDs instead of neons, these days.If it is one of these then it is the neon most likely:
[automerge]1587748954[/automerge]
Out of curiosity has anyone used one of them? For ÂŁ10 it seems very cheap but maybe it is OK.
You say they were fine but what are the results of your testing?the reading was between line and neutral read low and the line and earth was fine as for the neon mmm I can not recall if it has one
phil
If you must carry out a L-N test always start with a soft test at 250v.
It is a shame that testers don't automatically start at 250V and then only go up if it looks like an open circuit (say > 1M or maybe more) meriting more volts to verify that.
The cover is a nightmare hard to open hard to closeI've fitted a few of the BG ones, and to be fair they are OK, but they just feel "plasticky" and in addition lifting the cover is not easy, as it is a very tight fit. However, for the money they're fine for occasional use. Personally i would fit something more up-market if i were to be using it daily.
Yep it's the 2 clips that are the problemI've never found the cover on the BG one hard to open or close, but I haven't fitted one for a couple of years so maybe they've changed.
They used to have two clips at the bottom you undo and then it hinges up easy.
Was given a couple to fit. They seemed ok, until the covers started breaking off within weeks. Poor quality. Same goes for all BG IMO. I use hager ip66 sockets now or click hager ones re a bit more expensive but very well built.If it is one of these then it is the neon most likely:
Reply to British General outside socket in the UK Electrical Forum area at ElectriciansForums.net
