BS AU7 wire colour question
I have allocated a colour to every wire now, but I can't agree with the statement that there is a colour for everything within the British Standard.
There doesn't appear to be one for a tachometer fed from a contact breaker - I am intending to use black/blue for this function, which is the colour for one of the wires normally used to supply a tachometer from a generator, so a little adapting, or substitution, will be required.
The 2CV also has a wire from the hazard switch to the flasher unit - I am told that this is peculiar to Citroen, because of their own switch design, and, as a result, there isn't an allocation for that connection.
i suppose that one could say that there is a colour within the British Standard for every wire - except when there isn't !
John
I wouldn't have thought a French Citroen would be wired to British Standard AU7 or am I missing something
Ah!
this is because it's a very British Citroen - he is named "Ethelred", and is a "limper", that is, he only has three wheels.
if you google for Pembletons, you should end up on their forum - if you look on the chassis register you will see both four wheel and three wheel versions - mine is number 39.
all will then be sparkly clear!
I bought the Haynes car electrical manual many years ago and that had a full list of the British wiring colours.
A good supplier is Vehicle Wiring Products and I found their non-adhesive loom tape much better than using normal insulating tape for looms as it allows the loom to be flexed easier.
I had an ex who made wiring harnesses at volex,the tape they use is only about 10 mm wide,shame really because when she found out I was a spark she offered to get me my tape for free,trouble was it's no good being so narrow.mind you life's full of dissapointments,my ex wife was a very slim blonde and earned her living as a stripper, unfortunately the stripping involved cooked chickens in a factory,still on the up side there was no waste when we had one at home.lol
Hi John.
I off line for a couple of days
If you need to be correct the Tacho wire should be white with black trace.
cheers Neil
