BS number for main switch on old wylex rewirable boards | on ElectriciansForums
Discuss BS number for main switch on old wylex rewirable boards in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
A
adasadas
Fellas,
What is the BS number for the main switch on a Wylex type rewirable board? Is it still a 60947?
thought it was 60/80a bs5486 199a bs5419:)
oops that should be 100a bs5419:eek:
Unfortunately not. BS5486 is more to do with type testing of the enclosure and associated equipment. This has now been superseded by BS EN 60439-3-1991.
Therefore: -
BS5486 is now BSEN 60439-3 - (enclosures)
BS5419 is now BSEN 60947-3 - (switch disconnectors)
Similar looking numbers, but not the same standards. ;)
As I understand it then for my PIRs I should refer to the main switch in the old rewirables as a 5419, and in a modern it'ss a 60947-3?
the rating is variable, 60-80?
I actually saw one today for the first time that had '45a or 80a' written on it. Normally there's nothing.
I dont want to appear dense, but pevvers, could you elaborate on the enclosures comment and the reference to BS 5486? What do you mean by the enclosure, the box of the DB?
Yep, normally the new ones will have either 60947-3, IEC 947 or something similar stamped on them, the old ones are more tricky. The rule of thumb I would go by is that if there's nothing on it, then it'll probably be a 5419.
I'm not sure if the rating is variable. I think the smaller old Wylex are rated at 60A, whilst the bigger 8-10 ways are 80A.
You're not appearing dense in the slightest. It's only because I had a quick search for BS5486 through the standards and saw that it was superseded by BSEN 60439, which is one I am familiar with. As far as I am aware it relates to the overall safety of the enclosure and all associated equipment, so the case, MCB's, switch disconnectors etc., etc. It means that it has been type tested and conforms to many different tests to ensure that it stands up to whatever may be thrown at it throughout its lifetime.
I am no expert on type testing as I have no need to get into it as of yet (although I now have access to most British Standards so may have to change that), so I will happily concede to whoever knows more, as I am here to learn like the rest of you too! :)
The abstract text from BS EN 60439-3 is: -
"Gives supplementary requirements for such enclosed distribution boards (DBU), which are stationary, type tested assemblies (TTA) for indoor use, containing protective devices and intended for use either in domestic (household) applications or in other places where unskilled persons have access for their use. Control and/or signalling devices may be included. They are for use on a.c. with a nominal voltage to earth not exceeding 300V. The outgoing circuits contain short-circuit protective devices, each having a rated current not exceeding 125A with a total incoming load current not exceeding 250A. The nominal voltage to earth in an IT system is taken as the nominal voltage of the system."
Make of that what you will, but I shall see if I can actually read the full standard this late at night.... It's probably not looking good though! :)
Right, blah blah blah. Yes, it seems to be just the type testing of the enclosure and related bits and bobs. It's not easy to read but I can't seem to see anything more in it than that! I hope I've helped, :)
WELL IF I AM LOOKING FOR THE DIFFERENT TYPE. OF BS5486 FOR MY CERTIFICATION.
AND IT'S COMING UP ON NICEIC DROPBOX AS A BS5419.
AND THIS IS ON THE CONSUMER UNIT AS A BS5486.
WE MUST BE GOOD AT SOMETHING. REGARDS MICKY RYAN
Reply to BS number for main switch on old wylex rewirable boards in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hello, I hope you are well, a friend has lost power and it's the main switch that has failed I've got a bunch of different brands in the garage...
yeah so it looks like an old off peak heating circuit to what would have been storage heaters my preference is to remove them completely from the...
