bs88 for single 230v | Page 2 | on ElectriciansForums
Discuss bs88 for single 230v in the UK Electrical Forum area at ElectriciansForums.net
A
allybally
I know this might sound like a daft question and I think I know the answer, but a Hager bs88 fuse carrier is rated at 415v three phase, I want to use it for 230v single phase, for a welder, I take it there's nothing wrong with that as long as the readings are ok, I haven't tested or even installed it yet but I'm on TN-S and very much doubt I'll get the Zs even close to low enough
Thanks and be kind :)
I would try not to use an RCD if possible.
If you do not intend using the welder outdoors, then as described there is no requirement (as yet) for RCD protection.
Is the welder stick or wire?[/QUOTE
It's going to be only inside by myself a skilled person :-S so no risk assessment needs to be considered yet and it's a wire fed Mig welder, will be hard wired
Seems really wierd.
Not sure of the AMPs of my welder, but I believe it is greater than 150A.
Unfortunately, there is no equivalent currently being produced.
I've used it in a variety of places, on all settings and never had it trip out anything other than the odd 13A plug top fuse.
allybally, you state in an earlier post in another thread that you hold the C&G 2396. Are you sure, or was that a typo?
I'd expect this question to be Janet and John for someone who holds this qualification?!
I'm not being rude, I'm just slightly confused???
I'll have a measure of Ze tomorrow but it would have to be a pretty low starting point wouldn't it, to use a breaker with max Zs of 0.46
are sure you need a 100amp supply to welder?
Thanks, mine is output 150 amps, in current max 21amps not taking into account of inrush, in my old house I had a 25 amp type C that tripped when the arc struck
And wasn't that handy
hmm could be a windup mate
Hey I do hold this qualification, I just don't have any experience with welders so thought I'd ask that's all, just because I hold this qualification doesn't mean I know everything
Reply to bs88 for single 230v in the UK Electrical Forum area at ElectriciansForums.net
Adding a led strip isn't going to make much difference to the 3 phase balance. No real difference to where a 3 phase machine uses one phase to...
