bs88 for single 230v | Page 4 | on ElectriciansForums
Discuss bs88 for single 230v in the UK Electrical Forum area at ElectriciansForums.net
A
allybally
I know this might sound like a daft question and I think I know the answer, but a Hager bs88 fuse carrier is rated at 415v three phase, I want to use it for 230v single phase, for a welder, I take it there's nothing wrong with that as long as the readings are ok, I haven't tested or even installed it yet but I'm on TN-S and very much doubt I'll get the Zs even close to low enough
Thanks and be kind :)
Bloody hell it was a simple question, I've never come across a bs88 fuse in domestic before (not the bs88-2), didn't even know you could get a din rail mountable carrier that would fit inside a consumer unit, normally just use MCB's, even my wholesaler had not heard of them, just wanted to do it right! 1st time...
No need to swear mate. People are trying to help you, but if you don't supply the correct and sufficient amount of information it's impossible to do so. The solution is in your hands(fingers)...
but it in answer to the original post, yes. Does that help?
Hi Ally.. I'm not interested in the 'discussion' thats going on here, but I often seem unable to upload pictures/files IF I am trying to do so half way through a thread.
The way I have got around this is by clicking on the 'go advanced' button to the bottom right of the box you are writing in and then upload the picture as normal by clicking on the icon that states 'insert image' as you hover over it.
Good luck and well done for not getting too worked up!
Well I'm disappointed with the end to this thread...
I was looking forward to you eating that humble pie Mr DS :wink:
I guess we'll never know!
Reply to bs88 for single 230v in the UK Electrical Forum area at ElectriciansForums.net
Adding a led strip isn't going to make much difference to the 3 phase balance. No real difference to where a 3 phase machine uses one phase to...
