Burnt out ballast EICR Coding | Page 2 | on ElectriciansForums
Discuss Burnt out ballast EICR Coding in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Regulation 642.2 (iii)
The inspection shall be made to verify that the installed Electrical equipment is:
Not visibly damaged or defective so as to impair safety.
This is from the 18th edition so naturally it’s predecessor may be different but I do not have the 17th available at the moment to compare.
Now admittedly this forms part of the initial verification process but I’d be prepared to use the same regulation method for periodic inspection
Also see 651.2 regarding periodic inspection and testing note (ii) in particular
I was going to look for a specific Reg tomorrow but I had absolutely no doubt that a Reg would be there to cover this.
How can anyone even think it is ok to no code this is beyond me.
It’s almost the same(tongue in cheek) as a burnt out pin on a socket but ignoring it on the grounds that it’s not fixed wiring.
It is worded differently in both book.
Reply to Burnt out ballast EICR Coding in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Agree when you have a Senior Moment how is that still allowed, especially with all the regulations in place now, always a dangerous situation in...
Hi James, At the inverter end the multi strand is ferruled and torqued in the terminal and at the motor end they are the “wago type” push fitting...
