HAHA, Fair enough, if it was a 3" capping with 4 or 5 cables under it and not a 1" with 2 as the OPs question I would totally agree.
Isn't grouping associated with number of circuits? So:
In the case of 2 x 2.5mm cables going to a socket outlet then how many circuits is that?
In the case of 1x1.5mm T&E cable and 1x1.5 3core cable then how many cicits is that (usually)?
Yes quite right, and when would 2 different circuits be under a 1" capping ?, unless the design was very bad never IMO.
what about all the circuits running down the wall to a CU ?
you'll need a 4 ft wide chase if you want seperate capping for each cable lol.
And what a useful intervention....
Grouping should be considered but 9 out of 10 CU's have grouped cables and do we go round derating them??????????????
Never had a 4ft wide capping area before biff, if that was needed due to a large home needing wiring I would work with the builder to design a better way, and move the board to a better location, still if your happy?
Anyhow whats this got to do with the OP question about 2 cables under a 1" capping?
i sense a complete humour breakdown on the forum tonite so bugger the lot of ya with your dumb arguments on capping.
i'm off lol.
Cable grouping within capping behind dot and dab
officer dibble,
Top Cat,
TrueNAS JBOD Storage Server
