I had a problem a couple of days ago with my boiler shutting down due to too high temperature difference between the input and output, which transpired to be because the boiler had been wrongly wired.
I have two zones in my heating system, so as I understand it there should be 5 wires between the controller and the boiler - L, N & E plus two switched live. But there was only a 4-core cable so the boiler had been wired in a slightly different way to accommodate this. Interesting to speculate whether the cable would have been fitted by the plumbing or electrical contractor in a new-build house! Anyway, it is what it is - but practically impossible to rectify as the two ends are on different floors and not directly one above the other.
The gas engineer who came to check it out rewired in a different way but acknowledged that it's still not optimal. He speculated that I may be able to do something with a wireless connection between the boiler and controller. Any ideas about how to do that, and what I would need to buy?
The number of zones is irrelevant, boilers will require either 4 core or 5 core depending on where the pump is located.
For a system boiler, or if the pump is located adjacent to the boiler, 4 core to the rest of the controls is sufficient.
If the pump is located with the valves etc then a 5 core is required to allow the boiler to control the pump.
So as I understand it, you have L, N, E and only one other core going to the boiler, but you need two because you have two control functions: demand signal from valves to boiler and the pump control from boiler to pump. The latter has been missing until now, and the lack of pump overrun has caused the flow temperature to go over limit. Your suggestion is to transmit one of those functions with a wireless link, and @davesparks suggestion is to relocate the pump adjacent to the boiler so that the pump can be wired directly to it.
If it were mine, I would make some kind of simple multiplexer device to enable both the demand and the pump control to be transmitted in opposite directions over the one available cable core. It would be an hour's work with a couple of relays, diodes and transistors, but I wonder whether such a thing exists commercially in an easy-to-integrate form, that would avoid having to rely on wireless?
If it were mine I'd probably use a delay-off timer to keep the pump going for the required time.
As far as I know the pump overrun on boilers is a simple time based thing and not actually based on temperature.
Assuming you have a permanent mains supply at the end remote from the boiler, you could use this:
If it were mine I'd probably use a delay-off timer to keep the pump going for the required time. As far as I know the pump overrun on boilers is a simple time based thing and not actually based on temperature.
That sounds like a simple and practical solution. In the past there have definitely been boilers with thermostatic control of pump overrun, via separate contacts on the stat. I've never had cause to investigate how it works on modern boilers, but perhaps it doesn't really matter, so long as the pump doesn't just stop the moment the burner goes out.
The Mainslink remote control solution looks like a neat, practical device too. If it can do 1km indoors (?!) it ought to be pretty reliable from one floor to the next unless your building is a mass of rebar.
Are you selling these or something?
I'm beginning to think you are selling these Avo 😀
As Lucien and davesparks say, it's not really important how long the pump runs after the boiler shuts down as long as it runs for long enough to remove the heat soak. A simple delay off timer would be an effective solution.
You could do away with the timer and install a hive reciever in the area where the zone valves are.
A 2 channel hive (or similar) would work and leave you an extra core if needed as the hive only needs a 230V supply
You would still be able to connect things to this such as remote thermostats etc.
How would that solve the problem?
Unless I am reading it wrong there is one core short at the junction box (where the zone valves / cylinder are)
The Hive (or similar) only needs a L,N,E so the reciever can be located adjacent to the joint box. As the reciever will give you seperate switched lives for HW (on), CH (on) and even HW (off) if you need it in the cylinder cupboard you will have a supply and switch wires needed at that location.
Am I missing something?
Yes there are 4 cores between the joint box and the boiler when it requires 5, so the pump cannot currently be connected to the pump terminal of the boiler.
The controls, whether they are wired or wireless have no bearing on this part of the circuit.
I would have the 4 cores as
L,N,E - supply to JB (install hive reciever at joint box)
4th core pump over run
The hive adjacent to the zone valves stops the need for the s/l for the CH and HW as it can now be derived from the new hive reciever (in the cylinder cupboard)
But if the receiver is in the cupboard, the problem is getting its output to the boiler.
I was assuming the 5 cores went from the boiler (FCU) to the cyliner cupboard.
By moving the reciever for the programmer you now have s/l for CH and HW adjacent to the pump and motorised valves, the 4 cores you have will do L/N/E/SL - boiler.
The existing programmer would now be redundant
Operating the valves from the programmer is not the problem. It is getting SL from the valves in the cupboard to the (remote) boiler, and the boiler's pump output back to the pump in the cupboard. For these two functions there is only one core. Previously, the core was used as SL to the boiler and the pump was operated directly in parallel, but the lack of overrun caused boiler overtemp. Hence the present offering of solutions: Move the pump adjacent to the boiler, leave the pump in the cupboard and control it with a wireless link from the boiler, or ignore the boiler pump output and provide a timer in the cupboard to create the overrun.
On balance the wireless link is probably the neatest option. Moving the pump takes it from a cupboard to a usable store room so is marginally less suitable, though technically sound. But at least I have two viable solutions.
The system is already run through Hive. But moving that upstairs puts it one floor further from the router so anyway would not seem like a good idea, though it seems that doesn't work anyway - the issue is the power to the pump.
From a technical perspective moving tbe pump is tbe simplest option which leaves you with the least number of potential failures.
Baku, Azerbaijan
Electrical Enthusiast (Unqualified Hobbyist etc)
Cable missing in central heating wiring
naylorpd,
davesparks,
