Cable needed to connect RCD to the DP main switch & neutral bar. | on ElectriciansForums
Discuss Cable needed to connect RCD to the DP main switch & neutral bar. in the Australia area at ElectriciansForums.net
Goody
London
Hi,
Trying to add an RCD to a wylex board that never had one. My issue is to get hold of those flexi cables that connect it to the DP main switch and the neutral bar. I have managed to get a set for a twin RCD board but does anyone know where to buy them in required lengths individually?
Thanks!
its probable that your old board hasnt got 2 neutral bars neither, by the time you have got an rcd and sourced the tails in question it would be much less hassle just to buy a split load board as a whole
yep....more time than its worth faffing about here.....and the old c/u can be used for a temporary power supply....or for a garage......
Reply to Cable needed to connect RCD to the DP main switch & neutral bar. in the Australia area at ElectriciansForums.net
Also use a tails gland and clamp if available and make sure tails are secured to a wall. The danger here is a live to earth fault in the Consumer Unit
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
