P
potatoman
Hi ,how do you check the resistance of a cable thats about 140m long, goes through 3 consumer units and between the consumer units it is different sizes
Discuss cable problems in the UK Electrical Forum area at ElectriciansForums.net
be better than using a gas meter.can I use a ohm meter
thought i did in post#2. measure the resistance of each section, the add them up. low ohm meter, then a pencil and paper ( or , if you are flush, a calculator.)How about answering the question
how about learning to be a spark..How about answering the question
How about getting him to provide a test certificate for the job done. For the 10k paid, I think it should be expected.I am no spark,but at least I know it,just spent 10k on a solar PV system ,the so called trained electrician never checked the AC cable like what has been sugested and now it does not work and all he wants to do now is increase the paramiters of the inverter
Reply to cable problems in the UK Electrical Forum area at ElectriciansForums.net
