Cable routing inside a consumer unit | Page 4 | on ElectriciansForums
Discuss Cable routing inside a consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Manchester
Hi
First post and I'm a DIY-er so apologies if this is the wrong forum to start with.
I have a project at the moment that involves replacing a consumer unit. I've arranged for a proper inspection and certification down the line but in the mean time I have made a start on getting the circuits wired in where I can.
This is where I'm up to so far:
and this shows better how the wiring is routed:
I know some of the sheathing on the incoming cables is probably a bit long, but they may move so I've kept a bit of excess. Likewise the neutral and earths are looped as shown to maintain some excess.
The question I have is, is there anything particularly wrong with that routing?
I wasn't sure if it was best for the cables coming from the top to drop straight down and the ones from the bottom to go straight up, or if they should be routed along the bottom and up the sides, e.g. the single one there at the moment, would the earth be better going all the way to the left along the bottom and then up the left hand side, and the live and neutral the same but to the right?
Oh, last thing - this is the bigger picture:
I've added an isolator, looking at it now I think the meter tails should probably be shortened a bit, or at least clipped out the way.
Any advice guys, or anything else that stands out that needs resolving?
Thanks...
I've been away and haven't had a chance to post an update but I have made changes.
The 2.5 radial is now on a 16A MCB.
Cables entering the CU are 1 circuit per grommet with no visible gap between the cable outer sheath and the grommet membrane.
Tails and earth cables are retained with metal banding. The service head, meter and CU are to be enclosed in a cabinet which has always been the plan.
The cables running up the wall in the trunking were already also retained with metal banding screwed to the wall at intervals not exceeding 400mm, which is also the method of retention in the walls before being plastered over.
Also checked the main fuse rating is 60A as I recalled.
I don't disagree - there's currently nobody in the property, I'm only doing any work at all on the basis that the homeowner has it tested by a qualified electrician before they move in.
Is the home owner actually aware that you are not a competent person and are expecting them to arrange for someone to test and certify it.
Yes, 100%
I'm not claiming to be qualified or able to say it's all correct or anything like that. The home owner has bought the property to modernise (on a tight budget) and I've said I'll help as long as it's checked over. I wouldn't want his wife and kid in there until then.
To be honest, if left to him it would be lethal...
Reply to Cable routing inside a consumer unit in the UK Electrical Forum area at ElectriciansForums.net
IMO Better to do something about those ignoring regulations first! Current system is like having a speed limit but not enforcing anyone without a...
Thanks for the replies, I appreciate it.
