back to page 123 of osg and read post 32 again to calc It
no point telling you the answer if you can't explain it ;)
cable size??
It =24/0.8 = 30
can you find the cable size from table 6D1 page 128 of OSG?
What a complete knob I am , sitting in bed watching Darren Brown doing calcs in me head, plonka plonka plonka
anybody else want throw in a few insults its open season for me
But only unit 6am tomorrow so get in quick
remember voltage is 400V so can expect to get considerably more power and 3x that because there are 3 phases :)
You would also see if Vd was ok using Vd = Ib x Length x mV/A/M (value found from table 6D2) it turn out ok - well less than 5%
These lecturers always keep the really tough questions til last means they won'tbe stuck withnothing to do at the end of the lesson ;)
hope i've been some help and not made some stupid mistake somewhere.
Think your all wrong here . 50kw is 217.39 amps split over 3 phases , 72.46amps per phase. its oven resistive load. nearest breaker 80amp triple pole . instaled in trunking ref meth 4 , 3or more cables . requires 35 mm cables. rating 89amps. from quick look . night all. Michelle.
so how would the lay out work? i take it its just ran out the CU
you have been a great help thank you very much
I wouldn't bet my life on me :D but your 217A figure comes from using 230 volts! It is 3 phase so you should use 400V and root 3
probs to an isolator then to the motor - remember there is an mcb for each phase and if it is a motor they won't be type Bs
you still not seeing that button lol
brain in gear (just)
50x1000 50000
1.73x400 692 = 72.25a ( no correction factors taken into account)
50x1000 50000
correct and then share between 3 phases.
Edit: on reflection think your 72A is Il (line current) as the formula is for total power! so factors and mcbs should be done on that figure oops!
cheers mate
Hey - you found that button :D
Edit ; when you have time have a read of the OSG chapter 6 and Scadden is a brill book for the theory - believe there is a new edition out now as well - well worth buying to get you thru your exams.
just logged on to the office pc and computer says---
50kw - 90.32 amps length 50m voltage drop 11.29a type d mcb didnt allow for correction factors
Good Night
soo what you are saying is the total power is 72A this then needs to be shared with 3 phases witch brings it to 24A per phase?
calculate the desing current w/1.732 x 400 and that will supply current per phase (is what i should of said) unless there is a pf involved
cable sizes
Talk Electrician Forum
james king,
james king,
