cable sizes | Page 3 | on ElectriciansForums
Discuss cable sizes in the Talk Electrician area at ElectriciansForums.net
:)Have a look at page 123 temp at 30C has no affect so can be disregard it in this case (table 6A) the other circuit derates it though-look at top line of table 6C (p126) . You will need to divide your current by 0.8
tricky question this one :)
some1 help bugsy how did you work it out and what amps per phase do u get? im confused about the incoming tails say they are in 25mm per phase in to the board would u then come from the DB to the switch panel if so what cable size would u use then? can u some how find a diagram of it please mate
Reply to cable sizes in the Talk Electrician area at ElectriciansForums.net
Well another week passed and I still don't have a proper answer to where the process is wrong. To reiterate, this is not a question for a real...
Good question now to start with thermosetting insulated conductors are not tri-rated that is something different. Table 4E1A deals with this type...
