Discuss Cables in cavity of walls in the UK Electrical Forum area at ElectriciansForums.net
Won't be an issue after BrexitKnown as chemical migration.
On new builds we are required to run the cable through conduit.So to repeat Telectrix's question, how would you run a cable through a wall for an outside socket, security light, etc?
Cable TV companies will just drill straight through (mine did years ago) as will satellite dish installers.
20mm hole through or use a bit of plumbers pvc pipe to sleeve the cable.
Nowhere as far as can think without looking.Out of interest where is that stated in the regs?
Just a requirement of the builders and the building inspector.
It's not a massive headache I've got no problem doing it.
I've also been required to place all cooker control switches to the right hand side of the cooker/ hob because apparently 95% of the population are right handed and wouldn't want the switch on the left hand side!Thanks, something I've often done too.
It was the "we are required" suggested it was a mandatory requirement......
LOL. I'm right-handed but mine's on the left-hand side. That said, I didn't wire it.I've also been required to place all cooker control switches to the right hand side of the cooker/ hob because apparently 95% of the population are right handed and wouldn't want the switch on the left hand side!
True story!
True story!
True story!
Reply to Cables in cavity of walls in the UK Electrical Forum area at ElectriciansForums.net
