L
Discuss Call out in the UK Electrical Forum area at ElectriciansForums.net
While we are on the subject of meltdowns, have a look at this
Looks like fair wear & tear to me.
Just get a new case for it & it'll be fine.
Do you know one of the problems i find these days , i torque have done for years ive had a burnt out terminal on one of my boards , cause was due to the neutral bar Splitting where the main neutral cable went in i didnt notice it when it was done only 3 years after i did the job when it melted !! , one of the main problems with all consumer units is the screws they are absolute crap im sure they are made out of lead put a screw driver on them and they slip then you cant tighten them so I have suggested to several manufacturers that they change them to torx head bolts and supply a bit they wont slip then
i dont like torque drivers, they can split the naff boards people work onDo you know one of the problems i find these days , i torque have done for years ive had a burnt out terminal on one of my boards , cause was due to the neutral bar Splitting where the main neutral cable went in i didnt notice it when it was done only 3 years after i did the job when it melted !! , one of the main problems with all consumer units is the screws they are absolute crap im sure they are made out of lead put a screw driver on them and they slip then you cant tighten them so I have suggested to several manufacturers that they change them to torx head bolts and supply a bit they wont slip then
Reply to Call out in the UK Electrical Forum area at ElectriciansForums.net
