Came across this today ....... | on ElectriciansForums
Guest viewing is limited
Discuss Came across this today ....... in the UK Electrical Forum area at ElectriciansForums.net
magnoliafan89
Hereford
Got sent to a house today to remove a supply to a shed down the bottom of the garden...maybe 20m away from board. Went out the 32a breaker in 6mm t and e jointed under a floorboard to 2.5mm armoured,down a wall to the outside and then under the garden. Entered the shed through a drilled hole and the earth into the banjo is just wedged into the hole.
4 double sockets lighting circuit and not sure what the 16a inside was for. But there was a pond powered off it whether that was the plugged in or the 16a.
As you can imagine she wasnt best pleased when we told her we were disconnecting it and it had to go.
[ElectriciansForums.net] Came across this today .......
Nic
e tidy job that:thumbsdown::tongue::mad:
Reply to Came across this today ....... in the UK Electrical Forum area at ElectriciansForums.net
I guess my last post was even less direct than intended.
nicebutdim
N
