Can anyone clear this up? | Page 2 | on ElectriciansForums
Discuss Can anyone clear this up? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The part of the installation you have ‘moved’ will need RCD protection. If it was a like for like replacement and you had not moved the light I would say no to installing RCD protection but I would comment on the MWC that it was missing.
Can you elaborate on this? As it conflicts with another members post, the cables I altered where not buried in plaster.
Then I am wrong. I assumed they were buried.
If surface then no RCD required. I would make a comment that RCD protection is required under current Regs but not dangerous.
A w.c is not a special location and is the same as not bonding your kitchen sink pipework, not required.
but.. what about the metal window frame that can be reached when sitting on the bog?
Reply to Can anyone clear this up? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
No to all. Also would require a means of isolation for PIV - pulling a fuse wouldn't be acceptable. I don't mean to seem disrespectful, but this...
nicebutdim
N
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
