Please can someone help to explain this
Please help urgently!
Many thanks
To be fair I am shocked and at a loss you are asking this question, and you plea for assistance is even more appalling, god help our industry.
Mike, I don’t think the op is a spark .... but they clearly have something to hide as they had chosen to conceal their profile from everybody .....
IMG 20180717 204316 - https://ibb.co/i9RBKJ
i9RBKJ
There seems to be 3 lots of live/neutral/earth. I saw this when I removed the old chandelier.
Problem is, it seems that the three neutrals were not connected to anything and of the three lives, 2 were connected to live and 1 to neutral?!
Is this valid or should I rewire it so that the three lives connect to live and the three neutrals connect to neutral.
Many thanks
Why is it urgent? What was the original job?
Wiring is pretty much standard but fitting should be earthed.
It's clear from the way you asked the question and the suggestion you made that you should NOT be undertaking this work and you pose a danger.
If the op had noticed one of the neutrals has a bit of marker tape on it it has been re identified as a switched hot
Any spark would know this.
Our wires are colored different but it's the same procedure.
To the OP please have a proper spark change It, It will be a lot safer for you
Leicester
Can anyone explain this - strange wiring?
DIY Electrical Advice
Shak,
gnuuser,
TrueNAS JBOD Storage Server
