Can anyone identify these meter tails? | Page 2 | on ElectriciansForums
Guest viewing is limited
Discuss Can anyone identify these meter tails? in the UK Electrical Forum area at ElectriciansForums.net
Reading
Evening,
Carried out EV charger installation survey today & found this meter. Is that a 16mm concentric type cable adapter between cutout & meter?
This is a TT installation, tails unprotected. Not sure about installation method of DNO supply.
I'd like to upgrade tails to 25mm between cutout & meter, looks like the tails adapter can be removed & replaced with standard tails?
Also - meter is only rated for 80A, unsure of cutout fuse size.
Maybe easier to have smart meter fitted & convert to TNC-S
[ElectriciansForums.net] Can anyone identify these meter tails?
I'm pretty confident it's TT although haven't metered.
Old meter in still in place.
Same Earth cable leaving box can be seen other side of wall connected to Earth rod.
Concentric incoming cable does not look like a TN-S cable.
I'll meter it before making any big decisions
Reply to Can anyone identify these meter tails? in the UK Electrical Forum area at ElectriciansForums.net
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
Recommended Sponsor News
Hi everyone,
Reading
United Kingdom
