can anyone relate to this | Page 2 | on ElectriciansForums
Discuss can anyone relate to this in the UK Electrical Forum area at ElectriciansForums.net
london
Replaced a faulty dimmer switch to a market leading V-pro and the lights were fine. gu 10 dimmable lamps
Left the job client said there was buzzing, i returned with another dimmer switch designed for GU10 LED lamps, once again no buzzing when i left however the lady emailed me asking me to return as they are buzzing.
I returned with yet another dimmer and the lights where not buzzing before or after i changed dimmer and no buzzing.
I HAVE JUST GOT ANOTHER EMAIL SAYING THEY ARE BUZZING
Could there be an underlying issue with her cabling, although if that were the case they would flicker no?
or is this client just being strange with me as this only occurs when i am away?
All electronics give off a slight buzz, but it comes and go. Could be dimmer, could be any one of the lamps once they've been on a while.
Was there a TV in the room? If that was recently turned to standby, there might be a buzz from that?
You cant keep going back and forward with replacement dimmers.
Reply to can anyone relate to this in the UK Electrical Forum area at ElectriciansForums.net
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
