can i fit an outside light ? | Page 2 | on ElectriciansForums
Discuss can i fit an outside light ? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
if i was his da-in-law, i'd have done the job mesself in the time he's been farting about, wondering if he can do it.
my dad in law , has one outside security light and wants me to fit an extra one. this will require a spur off the existing circuit and about 5 meters of cabling on an outside wall. can i do this work or does it come under part p?
Are you lonely tonight ? Do you need friends and someone to talk to ? You may have come to the right place.....
Share your thoughts and join us happy bunch of electrical retrogrades on the electricians forum chat line
I only managed to read a couple of replies and then lost the will to continue. So I may have reiterated another reply.
Part-P in only to ensure that all electrical work must carried out safely by a qualified electrician. As you have mentioned in your previous comments that you have knowledge about electrical installation then I don't think that it would come under Part-P. You have to first understand that how you will test the circuit to make sure that it's safe and can do it properly.
i was going to suggest fitting one of those stand-alone solar powered PIR lights, but then realised that he's need to be REAL and MCS registered and employ a scaffolder to erect scaffold.
Reply to can i fit an outside light ? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Outside socket… ok. But you say the fcu for boiler is beside the outside socket… is the boiler outside too? FCU’s have an IN and an OUT… the OUT...
Is it a retaining wall? If so I'm of the opinion penetrating damp is almost impossible to avoid. Make a channel underneath for runoff and slosh...
