Can i make a over head supply tncs | on ElectriciansForums
Discuss Can i make a over head supply tncs in the UK Electrical Forum area at ElectriciansForums.net
I'm not sure you can, unless you are a DNO, as I think the use of the TN-C section is covered by the ESQCR:
"8 (4) A consumer shall not combine the neutral and protective functions in a single conductor in his consumer’s installation"
As @Electro-tech says if you are worries about 30mA RCD having a single point of failure, you can use a 100mA delay RCD as an incomer, and either dual 30mA for final circuit protection or (ideally) RCBO that are neutral-switching such as the latest compact ones from Wylex/Crabtree/Fusebox.
Thanks can't get any help from supply authority as the supply from pole is privately owned
Unfortunately I have no idea how private supply/BNO style arrangements are covered for this under ESQCR rules. hopefully someone with more knowledge will be along soon such as @Julie. or a few of the usual suspects such as @James or @UKMeterman , etc.
on this occasion, I am unsure of the requirements and it would be foolish for me to guess and pass it off as advice!!
I think that in general, you either deal with the supply and earthing arrangements you have been given or you ask your supplier to upgrade it.
If the supplier is not the local DNO then i suppose if you want the earthing system changed you should ask whoever it is that is supplying you.
However, I would not support the idea of linking N to E locally. (I thought it should be ok, is not a good defence in court if it all goes wrong)
Reply to Can i make a over head supply tncs in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
