Can you take 2 phases to a consumer unit?
No mate, I'm not sure. Just quoted what the OP stated in his first post. Lest ask...
@Gigsy . Did you wire up this CU or do any changes to it?
We have removed a circuit from this board.
Don't know if my last post went anywhere Gigsy, may seem a daft question, and I'm only asking because I'm not sure what I'm looking at, but have you canfirmedthat there are 2 phases present, by testing the Voltage between L2 and L3
Yes 400v between L2 and L3
Long time since I did any 3 phase stuff, but that doesn't appear to be a very good design. Either of those two DB's could be altered over time, and without in depth knowledge of the installation, one could be significantly altered in preference to the other. Unlikely to happen in a single dedicated 3P DB, IMO.
Agreed a 3 phase board would have been a better choice.
Anyone else notice the screws arnt done up (top left and right) someone could lift it up and pull it off the wall :D
The board was not powered at the time the photo was taken. We took the bottom screw out, the top screws are meant to be loose, you hang the board on the two top screws, then secure it with the bottom screw.
It's Single Phase Consumers Unit and should be treated as such, not designed for more than a single phase supply, any difference doesnt comply with BS7671 In my opinion, don't really understand what all the debate is about.
Hi gigsy,
It's not a home made enclosure, but someone has adapted it in such a way as it no longer resembles or performs as it was intended. Therefore it's a home made adaption to fit a second phase that it was not intended for.
P.S. What is an electrical improver?
The board is modular. It is designed so that accessories can be taken out and added as needs be.
Google electrical improver.
Hi Gigsy, been keeping busy I see !
These boards are intended by manufacturers to be used for single phase. For more than one phase a 3 phase board should be used, in my humble opinion. I would drop an email to manufacturer's tech dept for their view.
I refer you back to wilko's post. Only way to resolve this is to contact the manufacturer.
It sounds as though you think this is fine, if so that's what should be in your report and put your signature to it.
This is your job, your decision. No one can tell you what to advise your customer.
Equally your customer does not have to do anything you advise.
Good luck with it.
What makes you say that this board is designed for a single phase?
If you look at the specs of consumer units, you will find they do not state they are designed for a single phase?
It might not be. So contact the manufacturer to find out.
If I where doing this job I would advise what I think, but it doesn't matter what I think. You advise what you think?
Good luck with it.
Thank you. I actually do not like the design, but I can not find anything specifically against any regulations. This is why I am asking people in this forum for advice. I am not very experienced and I submit to the forums superior knowledge.
Is there is regulation which state a 3 phase isolator needs to be adjacent to it, or did you just make that up? If so can you give me the regulation number please?
First point - worrying about the cost to put right is IRRELEVENT
Second point - if the installer had used a "multiple" phase board, then the board would have included a single isolator for ALL the board
Third point - best practice - I wouldn't install in that way
Forth point - Your duty is to improve / make safer - learning how to "cut corners" isn't a good idea
Fifth point - what did your mentor / boss say?
Boss don't like it either. We have been discussing what regulation it breaches, that is when I suggested I ask the forum.
Gigsy,
Bobster,
