What makes you say that this board is designed for a single phase?
If you look at the specs of consumer units, you will find they do not state they are designed for a single phase?
If it was a multi phase dB it would be designed as such, not bodged with two phases at the will of someone who ought to know better.
If it was a multi phase dB it would be designed as such, not bodged with two phases at the will of someone who ought to know better. Why on Earth would you want to stick two phases in there? highly dangerous option imo.
Why is it very dangerous in your opinion?
Looking at the way this thread is going I don't think anyone will come up with any regulations that prevent you using a 'single phase board' for a multiple phase installation. If it had a clear label on the lid stating that 400v was present, and that both isolators should be switched off before removing the cover I would be ok with it. It may be rough and look like a badgers nest but its not unsafe in my opinion.
Thank you for your objective opinion. I think I agree with you.
Looking the board up on Contactums website it complies with BSEN 61439, which states:
The new IEC 61439 standard applies to enclosures
for which the rated voltage is under 1000 V AC
(at frequencies not exceeding 1000 Hz) or 1500 V DC.
It's hardly a common type installation with 2 isolation points when 1 will be the norm, imagine a Domestic installer or Eletrical improver turning up to do some work, only to find two live conductors in what is a fter all an enclosure designed for a single phase supply.
You can argue all you want, but in essencee that is what it is, a Consumers unit desgned for one supply with one singe point of isolation.
Birmingham
Can you take 2 phases to a consumer unit?
Gigsy,
Bobster,
