Can you take 2 phases to a consumer unit?
If you really could not tighten them, use pan head screws and screw them back so they are nigh on flat against the wall, and then hang the board.
As to your first question, there are many occasions where DIs get involved in instalations that perhaps they should leave alone.
What exactly is a domestic installer, it sound like an inexperienced electrician? Is it like having P plates on your car after passing a driving test
Good point, I stand corrected. There is no such thing as a domestic installer, I guess. I was replying to another comment. I think we were referring to somebody unfamiliar with working on a 3 phase supply :)
It does not require a 400v notice as the nominal voltage does not exceed 230v.
Assuming it’s correctly labelled I see no reason why not. 1, 2 or 3 phases are all under 1000v, and the main switch itself is rated at 400v. Proteus used to make a 3 phase busbar for their single phase fuse boards so they could be used for that purpose, I assume it’s still available.
I think so did/do Hager.
Gigsy,
Bobster,
