Cannot get RCD test to work? | Page 3 | on ElectriciansForums
Discuss Cannot get RCD test to work? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Evening chaps..
I have just fitted some downlights in a bathroom and needed to give them RCD protection as there was none. I fitted the following:
[ElectriciansForums.net] Cannot get RCD test to work?
The test button works fine and the unit trips when a fault occurs (touching neutral to earth) but I cannot get the MFT to test it for trip times which I need for the MWC. Its a fairy decent MFT and I've never had any trouble with it testing RCD's before but I have never tested this sort of RCD before, it has always been in the CU. I make contact with the live/neutral/earth of something which the RCD is feeding, I get the little 'tick' on the MFT and then it just wont test.
Am I missing something simple here? Is this unit tested in the same way as you would an RCD in a CU?
however....you say it works on the test button.....but not at the load...
whip that RCD fcu off and make sure the outgoing CPC is connected....it may have come out when you pushed the front on...
or it may be that you didn`t connect it at all....as if the sleeving moved over the conductor then it could have given the impression that a secure termination had been asheaved....when in reality its not...
Should have proven all that if he's done the EFLI test before RCD test ,,
If the Zs is 0.9 then I don't see the touch voltage being set @ 25V being the problem, I would check the continuity of the CPC all the way through the circuit though.
I would also try the test at the outgoing terminals of the RCD with the outgoing circuit disconnected first too, to narrow down where the problem may lie, it maybe simply that the RCD is faulty.
Continuity of CPC was proved.
That is a very good idea Spark68 and I should have done that.
Which implies that he has not tested at the load terminals of the device. You test the device not the circuit
Would you not test the circuit as well Trev? When you test an RCD in a CU you test that on the circuit somewhere, generally a socket?
I don't know what all the fuss is about, i once spent and age trying to find out why an RCD wouldn't trip, i was testing on the supply side, took a while for the penny to drop, and not before i had stripped the bloody thing out before i realised what i had done.
So maybe i am a waste of space after all! :dunce2:
I never inferred that about you. This OP seems to get a lot of grief and I felt he was about to get a load more when he just wanted some help. I guess I was wrong.
Howard you have over 720 Thanks from us members here, your no waste of time M8, there are numties here though, and shhh, Don't tell anyone but there may be one in this thread hehe, I said maybe lol
Reply to Cannot get RCD test to work? in the UK Electrical Forum area at ElectriciansForums.net
Ok I’ll try this when I’m down
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
