Cannot get RCD test to work? | Page 4 | on ElectriciansForums
Discuss Cannot get RCD test to work? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Evening chaps..
I have just fitted some downlights in a bathroom and needed to give them RCD protection as there was none. I fitted the following:
[ElectriciansForums.net] Cannot get RCD test to work?
The test button works fine and the unit trips when a fault occurs (touching neutral to earth) but I cannot get the MFT to test it for trip times which I need for the MWC. Its a fairy decent MFT and I've never had any trouble with it testing RCD's before but I have never tested this sort of RCD before, it has always been in the CU. I make contact with the live/neutral/earth of something which the RCD is feeding, I get the little 'tick' on the MFT and then it just wont test.
Am I missing something simple here? Is this unit tested in the same way as you would an RCD in a CU?
Yes, I would for a dead accurate reading of device not affected by earth leakage out on the circuit.
I'm completely at a loss to understand what you're saying here. A bit back you're backing his method when it was pointed out (calmly and respectfully) that he was carrying out the test wrongly now you appear to be backing up what I said but only to get "a dead accurate reading"
Why would you not want a dead accurate reading?
Is he not just trying to confirm if unit is faulty. Probably only a got a bathroom light and a fan on load of this unit. He done I/R and ZS and said it was good. Why disconnect load in this case? just more for him to do? That was where I was coming from.
I suppose really its a 'live' accurate reading. A 'dead' accurate reading wouldn't be great for a RCD test..
Sorry Trev, couldn't resist... just trying to lighten the mood!
Reply to Cannot get RCD test to work? in the UK Electrical Forum area at ElectriciansForums.net
Ok I’ll try this when I’m down
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
