Cant find fault!
R
rob121
Hi All,
First just wanted to say I passed my domestic installer a couple of weeks ago, so a big thankyou to al those who gave me advice and helped me out when I was a bit puzzled. So again thankyou!
Anyways back to the post, got callled to a job yesterday where the landlord had told me the tenant had complained that the "low level sockets" in the kitchen had stopped working. Anyways turns out its the sockets that supply the dishwasher and fridge/freezer. The house has only one ring supplying all sockets (built in 2004, new builds for you!), then off this ring theyve put a three gang switch, which supplies them and the washing machine.
So plugged my socket tester in and everything seemed okay, plugged dishwasher in - everything okay. So done IR tests, rcd trip test, cont test - again, everything fine. Took the switch and sockets off, no dodgy connections or anything untoward.
I cant see the customer had made a mistake either because he told me he left it for 10 minutes and still nothing, so hes pulled the dishwasher and fridge out, connected above worktop and volla it worked.
Has anyone got any ideas what it could be?
The only fault I found was that the three gang switch was rated at 20AMP fed of the 32A ring. Maybe its getting a bit warm inside and theres a dodgy connection inside?! Oh and forgot to mention that the dishwasher AND fridge went off both at the same time, and theyre fed seperately from the switch.
Interesting to see a new build with a 10mm main earthing conductor on a PME aswell :hurray:
Regards,
Rob
Thanks for the replies.
No loose connection was found! All the terminals were checked and nothing wrong there. The switch is wired properly (suprising enough) with ring coming in one end, links accross then ring leaving at other end.
I do think the switch has the potential to be overloaded as you have 3X 13A appliances on a 32A ring with the switch rated at 20A. I know they arent going to be running at 13A but perhaps start up currents on the washing machine/dishwasher could be causing overheating and maybe a poor connection inside?! Dont think it would make a difference but theres only 1 32A ring that feeds the whole house, kitchen included. But cant see this would cause the two sockets to stop working.
So far ive given the customer a report on what I found including the 20A switch not suitable for 32A ring-recommended changing for 3 X fcu, and obviously made the customer aware of the earthing conductor being undersized. What code on a PIR would that be? (Undersized main earth).
Thanks again, Rob
What about the continuity/IR of the radials and across the switches?
Also, the switch will not be switching 32A but only the size of the load connected to each of the switches, load side.
I cant understand how so many people have replied without stating the very first obvious thing you would check, is there voltage at the feed and load of the switchs?
Is there power leaving the switchs?
I find it amazing how you gained domestic installer and cant work out basic faults like this, sorry if that sounds harsh, but it seems they give anyone a domestic installer
im suprised you managed to get this far on the forum if you cant read. As said before theres power leaving the switch and all the sockets are working fine, test results fine. So its an intermitent fault. Perhaps next time its worth reading the thread properly before making a judgement on someone.
Rob
IR tests fine, continuity fine.
As far as the switch goes, the fact its rated at 20 A would this be for each circuit or for the switch as a whole? I would have thought it would of been as a whole but perhaps not
I read your original post, which says nothing about checking for voltage, hardly fault of the year is it, basic things which are learnt in your first few years, do apologise if i seem to have upset you, i stereotyped you as being a kitchen fitter, whos been signed off in a few weeks
"So plugged my socket tester in and everything seemed okay, plugged dishwasher in - everything okay"
I would have thought that would of given enough info to say that there was power to the sockets. And with 20 odd replies and no one pin pointing the problem yet I would hardly say its a basic fault such as a loose connection.
Anyway I'm not going to get into arguement about it, as thats not what im on here for.
Rob
Each of the switches is rated at 20A, not as a whole, and as each switch is only switching 13A max then they should be fine. The terminals will be rated at 32A.
As Tel said if all connections are sound then it could be faulty switches.
Calm down flower, its hardly my fault you dont understand basic faults is it
For what its worth i reckon they are just cheap **** switchs which have broken down and create a intermittent fault like the other electricians have posted, for me id of just changed them for a more reputable make instead of making yourself look incompetant
Its hardly my fault you obviously dont have any common sense. Well isnt replacing the switch part of the advice I put in my post. The thread was started just out of interest to see if I was missing something other than the basics. Im sure youve never had something bug you and ask a general question about it. Anyway, so far your advice has been check the voltage which i mentioned had been done, and replace switch which I had already said I had advised the customer before. Why dont you just start copying and pasting everyones elses advice, just to make yourself seem really "competant"
Im the one lacking common sense!?
You wouldnt last 5 mins working with us, ive met and worked with a few electricians of your calibre before, rather frustrating i must say
I really wouldnt shame myself of posting something so basic, if you were time served you really wouldnt need to ask these ill fated incompetant questions
God only knows how you scraped through a NICEIC inspection
I'd go with the dodgy switch theory, seen that before, sometimes you turn the switch on and nothing, turn it off/on again and it's "fine". I'd suggest a wee bit of functional testing on the switches would highlight that if it's the case.
Now Now Girls lets not get our knickers in a twist, if its not a loose connection, faulty switch would be a good bet, but others have said that already so don't know why I'm bothering really!
As much as I love discussing this with you vernam, i didnt join this forum to be one of them idiots making petit arguements and try to put people down. I joined it to gain a bit more info and when to clarify that the way ive carry out my work is correct, which by the way ive carried out the tests everyones advised im fairly happy I am. Now if you want to go on someone elses thread and try and derate them, maybe to make yourself feel better then go for it, im sure they will appreciate your helpful "advice" as much as what I have. I have to say all the time ive been on this forum Ive had some great advice and people have appreciated mine. Maybe you should read some other threads and at other peoples replies before going around making stupid remarks and trying to get in conflicts with people. Youve got a remarkable talent of being able to judge peoples competantcy from sitting at a computer screen.
cheers topquark. That was done and the switch seems fine. I tryed it with all the appliances connected, isolates them fine, closes fine. It just seems to come and go apparently. Anyway ive recommended replacing so im sure if it happens again ill get called out to change it over.
Cheers again,
Rob
On the faulty ones I've seen they often work fine, then all of a sudden when you try to turn them on again you get a bit of resistance and although the rocker goes over, the contacts don't make. If the clients turning them on/off regularly try asking if occasionally the switch seems "stiff".
rob121,
topquark,
