Can't get an electrician to come out for a small job! So help needed! | Page 4 | on ElectriciansForums
Discuss Can't get an electrician to come out for a small job! So help needed! in the UK Electrical Forum area at ElectriciansForums.net
Novice
b938qz
Hi Due to Covid, I can't get an electrician to come out to fit a single semi flush lamp. So I am going to fit it myself.
So some advice would be very helpful - but if you live local to Stratford Upon Avon and happy to come out for a small job, please let me know.
At the moment there is a standard ceiling rose with what looks like 3 (red) loop wires.
I have looked at some online videos and they say use a Way Go connector for the loop wires - is this correct?
Fixing and assembling I can do - but I want to make sure that I am wiring the electrics properly.
I've attached some photos - is there any tips you can offer?
Thanks in advance!
With lights like these I just take out the horrible black sleeve and worlds smallest connector block, fit decent connectors and earth the fitting. Better put a tin hat on I suppose. ?
i do the same.
I totally appreciate all the advice and opinions that people have given - all very valid and it is reassuring to know that there are a lot of electricians out there who are genuinely very safety conscious. However, I was starting to doubt if there was an electrician with a solution to wiring this light in safely - do either you or telectrix live near Stratford Upon Avon ??
I very well may be mistaken, but for my eyes it looks like the singles in the light fitting have a clear heat-shrink or sleaving over them. Is this the case ?
Are you in Stratford as your postcode is Solihull ?
There is the clear sheathing over the insulation giving those conductors the double insulation required. It’s the issue of getting 2 cables into the black boot and maintaining double insulation that’s the issue.
I'm not saying it's a good fitting I'm just checking (my eyes) to see if there is a clear sleeve over the wiring or not.
I assume ????? the design idea behind the black boot is that a homeowner just cuts off the existing bayonet fitting from the pendant strips back the two core flex to a shorter length and somehow fits the whole fitting over the ceiling rose, therefore no need for two cables to enter. Very novel!!
in other words, a light designed by someone who does not know the difference between a screwdriver and his arse.
I'm sorry mate, I'm in Cornwall and Telectrix is in Scouseland so from either direction it wouldn't be a cheap job. ??
Only just seen this thread, which side of Stratford upon Avon are you? I do cover Leamington Warwick and the surrounding area but Stratford is a good hour away from me as I am on the border between Northamptonshire Warwickshire and Leicestershire. If you are not in a major rush I have to look at a job out that way in a couple of weeks I could detour past and fit it?!
Sy
Sy
That sounds like a plan - happy to wait, as I can't go back to John Lewis yet because of lockdown. Are you happy to quote via here? Or is there an option to private message?
Reply to Can't get an electrician to come out for a small job! So help needed! in the UK Electrical Forum area at ElectriciansForums.net
It applies to commercial if it shares the same supply as a dwelling.
I am starting out as an electrician in Merseyside and have recently obtained my first ECS card. I have trained with an online colllege for the...
